Petromis
Jan 12, 2022Aspirant
Outgoing Emails being blocked since 1/5/2022 firmware update
Hello, All of my outgoing emails are now being blocked as Spam since the 1/5/2022 update. What was in that update that caused this issue and how do I change it back? I'm looking to reinstall firmwar...
Jan 12, 2022Guru - Experienced User
nielsvds
Jan 12, 2022Luminary
Here some more information what was patched: https://www.tenable.com/security/research/tra-2021-57
( https://kb.netgear.com/000064464/Security-Advisory-for-Multiple-Vulnerabilities-on-Some-Routers-PSV-2021-0279?article=000064464 )
You router doesn't have an anti-spam feature. Try also to contact your internet service provider if you aren't blocked because one of your devices is infected and was sending spam mail. Do you have another security software installed on your devices which also includes an anti-spam filter? Could you please post the error message that your receive exactly?
