Petromis
Jan 12, 2022Aspirant
Outgoing Emails being blocked since 1/5/2022 firmware update
Hello, All of my outgoing emails are now being blocked as Spam since the 1/5/2022 update. What was in that update that caused this issue and how do I change it back? I'm looking to reinstall firmwar...
Petromis
Jan 13, 2022Aspirant
I have the issue with all outgooing mail regardless of the recipient. (I have tried at least 15-20 different ones)
No, I have not enabled the VPN on the router.
It is possible that the IP is black listed but when I ran the lookup for my dynamically assigned IP, it only shows up on the Sorbs list I posted perviously.
The problems started occuring after Jan 5th, which is when the firmware patch came out. I had the router to auto update (that was my bad).
nielsvds
Jan 15, 2022Luminary
Thanks for answering my questions. If it is for all recipients thatn it is indeed related to the router. Because when you put it off everything works so no local security software can be the culprit.
Are you using openDNS for parental control? That is the only extra protection feature that your router offers.
https://kb.netgear.com/25687/How-do-I-set-up-Live-Parental-Controls-on-my-NETGEAR-router-using-the-genie-desktop-app
Netgear discontinued there custom services 12/31/21.
See here how to configure it: https://www.opendns.com/setupguide/#familyshield
Try to downgrade firmware : https://www.youtube.com/watch?v=tbcKq7BqNiQ
(for testing purposes, if related to the upgrade). Do you have custom firmware installed?
