Petromis
Jan 12, 2022Aspirant
Outgoing Emails being blocked since 1/5/2022 firmware update
Hello, All of my outgoing emails are now being blocked as Spam since the 1/5/2022 update. What was in that update that caused this issue and how do I change it back? I'm looking to reinstall firmwar...
Petromis
Jan 16, 2022Aspirant
Nope, I am not using openDNS or parental controls. I'm getting the primary and secondary DNS from my ISP. In testing, I tried google's openDNS of 8.8.8.8 and 8.8.4.4. It did not change the issue and is router related.
I have yet tried to downgrade the firmware but I did get the update before the Jan 5th one to try it.
nielsvds
Jan 16, 2022Luminary
The error message that you are getting in your mail software normally means that one of your devices is infected and sending SPAM. Did you already ran a security scan on your devices?
You also wrote this :
If I turn off WiFi on my phone (disconnecting to my network) the email goes through and I do not get the message.
So you do confirm that when you remove the router and let WiFi activated on the phone you can still sending mails. English isn't my motherlanguage so I want to make clear that I understood you correctly. You should also contact Netgear.
You can find the firmware upgrades also on the website: https://www.netgear.com/support/download/?model=R6400
You need to click to expand to show all previous upgrades.
- PetromisJan 26, 2022Aspirant
I solved my problem and I have to say how displeased I am to find out it was the Nighthawk router (that was only a year old) that was causing the issue. I replaced the router and the problem went away.
