JohnnyWB
May 17, 2016Tutor
QOS Setup problelm
I have certainly has my share of problems with hi-tech gear with this thing being no different and this has caused me to once again look to this community for some answers. I am having an issue with...
- May 24, 2016
Hi JohnnyWB,
Try other web browser. If same with other browser, reset the router to factory default and manually reconfigure.
JamesGL
May 24, 2016NETGEAR Employee Retired
Hi JohnnyWB,
1. What is the firmware version of the router?
2. What web browser did you use to configure the QoS System? Have you tried other web browser?
3. If the issue happens after you have updated the firmware, you may try to reset the router and manually reconfigure.
JohnnyWB
May 24, 2016Tutor
The firmware version is V1.01.6 and I am using windows edge to access it, in windows 10 home
- JamesGLMay 24, 2016NETGEAR Employee Retired
Hi JohnnyWB,
- VE6CGXMay 24, 2016Master
When you try other browsers, make sure you clear the browser cache first.
- JohnnyWBMay 24, 2016Tutor
10-4, thanks all. I will try it.
