Plumelec
Sep 26, 2021Aspirant
Répétiteur AC1200 Dual band ne fonctionnant pas avec ma nouvelle Box orange 5
Bonjour, Je viens de changer ma box orange 3 contre une nouvelle Box orange 5. Mon répétiteur Netgear AC1200 Dual band ne fonctionne plus. J'ai suivi les conseils d'orange pour cette nouvelle inst...
Plumelec
Sep 27, 2021Aspirant
Hello,
I have just changed my orange box 3 for a new orange box 5.
My Netgear AC1200 Dual band repeater no longer works.
I followed the orange advice for this new instllation, but it doesn't work.
https: //assistance.orange.fr/objets-connectes/installer-et-user/extenders-et-repeteurs/extenders ...
I would like to know if I am missing something or if the repeater model is no longer suitable.
Thank you for your help,
Plumelec
- FURRYe38Sep 27, 2021Guru - Experienced User
I would post about your extender/repeater in this forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
There will be more help there.
Also need to know the EX#### model number if possible.
Good Luck.
- PlumelecSep 27, 2021Aspirant
Dear Guru,
EX6130 WPS PIN 65871416
Thank you,
Best regards,
Plumelec
