Bengaljim54
Nov 13, 2020Aspirant
R 9000 nighthawk x 10
When I try to connect router to modem, all I get is the 60 Hz light lights up and does not connect to internet.
PauLita
Nov 13, 2020Luminary
Try to connect modem directly to PC.
- Bengaljim54Nov 18, 2020Aspirant
I'm not that great at computer stuff. So I connect my laptop from the modem by my wifi. Then plug modem to router then go to counterpoint. I bought this supposedly refurbished. So I'm think I have software error. So any suggestions I will be grateful.
- plemansNov 18, 2020Guru - Experienced User
It goes:
Modem----->router------>PC/devices
What modem do you have?
What firmware is on the router?
- Bengaljim54Nov 27, 2020Aspirant
Arris CM80A. I'm not sure what firmware is on it. Don't know how to check? Pretty much a rookie in computer and networking
