Please_HelpMe
Mar 04, 2021Aspirant
R6080 can't connect to 5G on computer
I don't know correct terminology but I need help please. my computer and kindle are connected to the internet by 2.4. My phone is connected by 5G. My kindle shows the 5G but says it's out of r...
michaelkenward
Mar 04, 2021Guru - Experienced User
My kindle shows the 5G but says it's out of range - it's sitting next to my phone, 10 feet from the router.
That looks like a problem with the Kindle. Tell it to forget the connection to the R6080 and set it up again.
my computer does not even show the 5G but it was using 5G this morning.
Again, look at the PC. If it can't see the 5G SSID, and you have confirmed that it is broadcasting, it is hard to see how the router is to blame.
How does the PC connect to the wifi? On-board chip? USB adapter?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
Please_HelpMe
What does it mean when you tell a device to "forget" a connection? I think I may have done that by accident with the 5G on my computer. Now the computer does not show it.
@Please_HelpMe wrote:my computer does not even show the 5G but it was using 5G this morning.
I'm not trying to place blame, I'm trying to figure out what happened and how to fix it. I callled Spectrum and they couldn't help, so I'm trying here.
I have no idea. I don't understand what you're asking.
I have no idea what firmware is or how to find it..
thanks for trying to help me
