Sasquatch3000
Jul 15, 2021Aspirant
R6260 <10Mb on 100Mb Charter/Spectrum service
Our R6260 was working great at first. We have Charter/Spectrum 100Mb service on a Charter provided Arris TM1602 cable modem. Slow past month,at 10Mb. Tried resetting and redoing entire setup on R6260...
Jul 17, 2021Guru - Experienced User
Try downgrading the firmware a version.
Do you get full speed when directly connected to the modem?
have you tried different devices hardwired in?
Sasquatch3000
Jul 17, 2021Aspirant
It was working fine on this version previously.
Yes
Yes. Works fine with different devices straight into modem. Does not work with those devices hardwired into the 6260 or on Wifi with the 6260.
Goes from around 85-95Mb down to 1-3Mb. It is like being on my old DSL line again.
- Sasquatch3000Jul 17, 2021AspirantWith the WNR2000v5, it now gets 21.82Mbs (100Mbs service).
- Sasquatch3000Jul 22, 2021Aspirant
Anyone else have any ideas on this?
What is the procedure for getting this fixed or replaced under warranty?Thank you.
- DarrenMJul 22, 2021Sr. NETGEAR Moderator
You would need to contact support here to have it replaced under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
