MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
Nov 04, 2021Guru - Experienced User
https://www.netgear.com/support/product/R6700v3.aspx
click on "downloads"
Then click on "+view previous versions"
jimfacteau
Nov 06, 2021Tutor
back tracked on the bios firmware to 1.0.4.118, same issue but not quite as often
- Rk2zRanchNov 06, 2021Initiate
Go one more posted update backwards! As in the 54+ postings above, you will then seek and find peace!
- jimfacteauNov 06, 2021Tutor
That is exactly what the game plan is tomorrow. Netgear doesn't appear to do the best at verifying functionality before these firmware updates go public
