MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
cochese187
Dec 27, 2021Tutor
Yes same here this is the most dumbest thing it cuts my BW in half also. Have to sacrifice security for speed. I thinks it about time to switch to asus for me... Netgear has no ambition to fix these issues at all
jimfacteau
Dec 28, 2021Tutor
as a follow up, I am trying to install the .106 firmware version seeing as this latest one is still an issue. Since the update, resetting and rebooting I can no longer log into Netgear Genie to revert back to the older firmware. The nighthawk app doesn't allow you to revert only go forward on updates. Does anyone have a solution to this problem? Asus is on my horizon!
