Dinky2534
Jan 21, 2021Star
R7000 - Time zone settings wrong after using Nighthawk android app
Why does my R7000 router adjust the timezone settings to the wrong time zone setting when using the Android app? The router is set to the GMT +1 time zone: (GMT+01:00) Amsterdam, Berlin, Bern, Ro...
- May 27, 2021
I've been running the 1.0.11.122 firmware for a few days now, which solved the problem with the timeserver!
Mar 25, 2022Guru - Experienced User
Might try a different browser and PC or laptop to compare.
Is the router well air ventilated?
Might check the power adapter as well.
Psychbum
Apr 13, 2022Star
FURRYe38 wrote:Might try a different browser and PC or laptop to compare.
I have exactly the same issue with the latest
| Firmware Version V1.0.11.130_10.2.118 |
When logging into the router management page, the logs are always 1 hour out. And the NTP don't save when changed.
| Current Time: Wednesday, 13 Apr 2022 02:25:00 |
| Time Zone |
| (GMT-12:00) International Date Line West |
| Automatically adjust for daylight savings time |
When I change the Time zone to
| (GMT) Greenwich Mean Time: Dublin, Edinburgh, Lisbon, London |
and hit apply the router reboots but reverts back to (GMT-12:00) International Date Time West
Are netgear going to acknowledge this and sort the issue?
Thanks
- FURRYe38Apr 13, 2022Guru - Experienced User
That's not the latest FW:
- AusmarkMay 11, 2022Aspirant
I'm using firmware version V1.0.11.134_10.2.119 and I am also getting this same problem.
- RealSunKaMay 22, 2022Aspirant
I just upgraded to the latest V1.0.11.134_10.2.119, with all multiple resets before and after, and with manual setup at the end. Overall, it's all great, including with 5GHz connection (some people have issues). However, the bug from this thread wasn't fixed still: I'm unable to change or rather NTP Settings, they always return to GMT-12 after settings "applied" and the page auto-refreshed.
The only option which could be stored on this screen is "Set your preferred NTP server", but it appears saved with an empty string even though I add server to that field before clicking "Apply". Interestingly, after this page auto-refreshed with such a wrong setup (empty server address field), there is no error and everything works fine. However, when I just set my time zone and leave this option as "Use default NETGEAR NTP server" (default state) I see a red error on the top of the auto-refreshed page about no internet and unable to reach NTP server, while everything continues working fine.
I tried changing this page setting on different machines (Mac and PC) and browsers (Safari, Edge, Chrome for both Mac and PC) - the same result on all of them.
Could this bug be a reason for Security - Block Sites - Per Schedule doesn't work also? Even when adjusting schedule for a wrong time zone.
P.S. And this site/forum doesn't work in Safari, apparently, forced to use Chrome on Mac to post something...
- PsychbumMay 22, 2022Star
RealSunKa wrote:Could this bug be a reason for Security - Block Sites - Per Schedule doesn't work also? Even when adjusting schedule for a wrong time zone.
I use safari on Mac and no issue posting!
I have managed to use manual NTP, but I shouldn't have to.
