kochin
Dec 09, 2016Apprentice
R7000 & R6400 Vulnerability Note VU#582384
[When I created this post, I wasn't aware of the 2 discussions already on this topic: Two leading Netgear routers are vulnerable to a severe security flaw R7000 Vulnerability Note VU#582384] ...
- Dec 15, 2016
Hi All,
The Security Advisory for VU 582384 has been updated.
Also, for more information and update see the thread below.
jrgreenman
Dec 15, 2016Tutor
That's good advice, but I'm really wondering if others have flashed the beta and can confirm that their settings remained intact or, at least, that the new firmware is able to successfully restore settings backed up with the prior firmware.
You guys must have tested this in the lab, yes? Did it work for you?
kochin
Dec 15, 2016Apprentice
After update to the beta firmware, I verified that all my settings on the router are intact. The settings I had customized and tuned to my likings are
- Internet Setup
- Wireless Setup
- LAN Setup
- Guest Network
- Device Name
- ReadySHARE Storage
- Wireless Settings
- Port Forwarding
- VPN Service
- Remote Management
I can report all those settings have not been changed.
- jrgreenmanDec 15, 2016Tutor
Confirmed! Router is updated and prior preferences remained.
Thanks for the reply. Gave me just the confidence I needed to take the plunge.
But yes, I wrote everything down prior anyway. :)
- ElaineMDec 15, 2016NETGEAR Employee Retired
Hi All,
