evilhomer1
Nov 17, 2017Tutor
R7000 5Ghz WiFi speeds
Hi all, I have an AC1900 router connected to an ARRIS SURFboard SB6190. I'm subscribed to Xfinity Internet on the Blast plan and can verify that I get 200+ Mbps when wired directly into the modem...
- Nov 21, 2017
I finally figured out the solution.
The QOS database was out-of-date.
Even though I don't have QOS on, apparently this can still impact the speeds because I'm back to running normally now.
To manually update the database, I checked the Enable QOS checkbox and then pressed the Update Now button.
Hopefully this will help others.
IrvSp
Nov 21, 2017Master
I can't say that this alone is the fix?
I have 100/10 Mbps service.
For testing I've been using an iPad Pro 5Ghz connection on the latest IOS (11.1.2). I use SpeedTest's app usually.
First let me say I never 'saw' the problem as even at 50 Mbps it was plenty enough for my purposes and only 3 other 5G devices in use and basically only one other at the same time. That speed was fast enough that there was no notice of a slowdown.
Additionally, the iPad was used some distance away from the router, and speeds below 100 Mbps when testing were common.
So after seeing your post I brought the iPad near the router and tested before doing anything. I looked at the RESULTS and up until 10/22 I was getting 114/11, and some of those tests were a distance away from the router. Now prior to 9/16 the results were quite different and even sometimes on the same day. The down speed varied greatly, from 13 to 114 with almost everything in between, even when tested 2 minutes later. What I can't say is WHEN any specific F/W was installed... but I suspect it was the 2 before this one.
That said, the first thing I checked was the database date/version.
| Version: v1.170,0.0.11 |
Release Date: 2017/07/23 |
Checked and it was the latest.
So I ran Speedtest, 76/11 Mbps???? Hmm... Another test, last night after I read this, 46/11 Mbps? Odd?
So I decided to ENABLE QoS and run the speed test there, 114/11 Mbps. I then set the router with this.
Test results were pretty poor, 17/11 Mbps (btw, most test are using the same servers that are fairly local to me)????
I then DISABLED QoS and reset the router. Poof, back to 113/11 Mbps.
So since I wasn't out of date for the database I doubt that either it was the cause or everyone is out of date.
So I'm more thinking it is the QoS speeds that are stored with the flash possibly? However I'm thinking that QoS doesn't only effect Wireless but all types of connections (otherwise it would be useless)? So QoS and its database probably aren't the answer here? More an internal flash problem that somehow is corrected by enabling QoS, running the speed test, setting the router for them, and once rebooted, disabling QoS. Of course, I could be completely wrong?
If a test on a wired PC with QoS off didn't see the same problem as a Wireless device I don't see how QoS could have been the cause?
windsaga
Dec 06, 2017NETGEAR Employee Retired
Hi All,
Would you try this trial FW ?
I think it can fix this issue.
