evilhomer1
Nov 17, 2017Tutor
R7000 5Ghz WiFi speeds
Hi all, I have an AC1900 router connected to an ARRIS SURFboard SB6190. I'm subscribed to Xfinity Internet on the Blast plan and can verify that I get 200+ Mbps when wired directly into the modem...
- Nov 21, 2017
I finally figured out the solution.
The QOS database was out-of-date.
Even though I don't have QOS on, apparently this can still impact the speeds because I'm back to running normally now.
To manually update the database, I checked the Enable QOS checkbox and then pressed the Update Now button.
Hopefully this will help others.
evilhomer1
Nov 21, 2017Tutor
Hoyty
Dec 07, 2017Apprentice
evilhomer1 wrote:I finally figured out the solution.
I wish I had found this two weeks ago. This should be official response from Netgear support after firmware upgrade.
