WelshJohn
Sep 11, 2019Aspirant
R7000 AC1900 totally "bricked" after attempt to update to latest firmware
Latest Firmware upgrade ended up totally "Bricking" my router, Followed all hints to get back up and running first thing that appeared to be screwed up was the Hard Reset after power on did not seem...
- Sep 11, 2019
> [...] the TFTP proceedure which is documented in many threads, [...]
I'll just go look at "many threads", then, all of which said exactly
the same thing(s), to figure out what you did? Guess again.> [...] with a fixed IP set up [...]
Which "a fixed IP"?
> [...] using the command lin prompts [...]
Which commands? As usual, showing actual actions (commands) with
their actual results (error messages, LED indicators, ...) can be more
helpful than vague descriptions or interpretations. Copy+paste is your
friend.> [...] i got amsg indicating [...]
What was the actual message? Again, copy+paste is your friend.
antinode
Sep 11, 2019Guru
Which "a fixed IP"?
friend.
WelshJohn
I was genuinly hopeing that i could get a level of help from this forum, but the confontational style of antinode Sensei is not contructive or a pleasant expiernce,
So i withdraw from this thread and ask the moderatros to close it please.
My next Router will NOT be a Netgear and possibly for the wrong reasons.
