Retired_Member
Feb 27, 2016R7000 BETA 1.0.6.40 ..........SOS..........Different version #
I was somewhat excited to hear that a Beta was being passed around today. 1.0.6.40 So I downloaded and installed it correctly. I entered my settings while off line using a wired connection. The 1st ...
- Retired_MemberFeb 27, 2016
With last Pulled version I had successfully disabled ARLO via arlo setup. Several days later I turn 2.4 off from the advanced wireless settings menu and arlo popped up.
This time with the latest FW I again successfully turned it off from the arlo setup page and when pushing the front button the main SSID's turned off and arlo popped up.
I have no interest in testing Jack Squat any further. If and when I need to use the r7000 I'll once again go thru the whole fricken default, reset , powercyle and while facing fricken mecca install 1.0.4.30 again.
Retired_Member
Feb 27, 2016News flash!!!!!!!!!!!! I just powered my r7000 off and Arlo disappeared. Arlo is an additional option added to the r7000 in the last FW that was pulled and apparently found it's way back into the beta and has same problems as before.
Arlo is a security camera which needs a separate host to work. Nitgear added this host option to the r7000 to save arlo users from having to buy the arlo host. or something close to it.
Mr_DJ
Feb 27, 2016Apprentice
I had no issues turning of the Arlo network in the former latest(now pulled) firmware version. Did not try turning the wifi completely off, but turning the 2.4 and 5 separatedly worked. However, I did it all through the firmware menu options. And no, this does not mean the same, as the signal from the button is a different programmed action in the units firmware! So try doing it in the firmware menu and let us know if it changed anything! ;-)
- sir_bazzFeb 27, 2016Apprentice
Hmmmm....my experience was different.
I disabled Arlo and applied it while monitoring with inSSIDer. Few minutes later, (it wasn't immediate), the Arlo SSID was gone.
Would strongly prefer the Arlo option was disabled as default but no big deal apart from the annoyance of having to disable it.
- mondenathFeb 28, 2016Prodigy
you are doing a mistake Why are you using the physical button on the router rather the gui based setting. You already know beta firmware could trigger anything since its not being final version. May be the physicall button is triggering all the wifi ssid.
More over the ssid for arlo in advanced wifi should have option though the arlo seperate settings.But for my setup the 1.6.40 is working fine with no arlo on . Its working stable for past 12 hrs and no hang or net issues as well. Everything is working well with over 9+ devices streaming from net and locally via connected USB with 2 more routers connected via WIFI-bridge and 2 readyshare is working in conjuntion.
Hope if you re-do without touching the wifi button and configure everything from router gui things should go smooth for you.
