Kleinza
Jun 16, 2016Aspirant
Re: R7000 Beta Firmware 1.0.6.54
after this update ther is no more connection with my arlo
- Jun 16, 2016
I had the new firmware for my R7000 , reset, and tried to sync the Arlo Camera with my existing MY ARLO App and account where the Router was saved- But the sync did not work. After adding the device/router once again everything worked out fine and I could sync my Arlo
Wolf_666
Jun 16, 2016Luminary
That FW is bugged and pulled out by Netgear. Latest is https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Official-Firmware-Release-Version-1-0-5-70/m-p/1100925#U1100925
ElaineM
Jun 16, 2016NETGEAR Employee Retired
Kleinza Did you try to reset the router after loading the firmware?
Just to verify, you didn't own a base station correct?
- KleinzaJun 16, 2016Aspirant
I had to conect the Router (yes, I do not have the basestation) once again with My Arlo. Now it works. Thank you!
- ElaineMJun 16, 2016NETGEAR Employee Retired
Kleinza Just to benefit others, what exactly did you do to resolved the problem?
- Wolf_666Jun 17, 2016Luminary
Thanks ElaineM for the update. I kindly suggest to put a sticky post for that so we can track versions in a better and cleaner way.
Ciao
- mondenathJun 19, 2016Prodigy
to avoid issues i thing firmware should reset the setting to factory including nvram
Just warn the user about it.
