Kleinza
Jun 16, 2016Aspirant
Re: R7000 Beta Firmware 1.0.6.54
after this update ther is no more connection with my arlo
- Jun 16, 2016
I had the new firmware for my R7000 , reset, and tried to sync the Arlo Camera with my existing MY ARLO App and account where the Router was saved- But the sync did not work. After adding the device/router once again everything worked out fine and I could sync my Arlo
ElaineM
Jun 16, 2016NETGEAR Employee Retired
Kleinza Did you try to reset the router after loading the firmware?
Just to verify, you didn't own a base station correct?
Kleinza
I had to conect the Router (yes, I do not have the basestation) once again with My Arlo. Now it works. Thank you!
