swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
Lucius1972
Oct 04, 2015Aspirant
Hi swehjo,
I also had wifi drops only on my galaxy S4, i managed to get them solved by using below values, maybe they help you:
- disabled WPS (Router`s pin)
- disabled UPnP
- disabled IpV6
- Fragmentation set to 2304
- RTS set to 2304
- Preamble: short/auto (have it on short now)
- Fixed channel 11 (use wifi analyzer to see the occupation for channel 1,6 and 11)
- MTU 1500
- Wifi mode 2.4Ghz: Up to 289 Mbps
- Transmit Power Control: 75%
Hope it helps.
swehjo
Oct 04, 2015Guide
Thanks Lucius,
But my problem is not wifi drops, its an "everything drops". Also the cable network...
- Lucius1972Oct 04, 2015Aspirant
That`s bad, tried different LAN IP? I put mine on 192.168.2.x
- swehjoOct 04, 2015Guide
You mean for the router? Sounds a bit off that an IP-address that I've used for the router since new suddenly stops working. Shouldn't be the root cause at least. But if you mean for the equipment I have maybe 10 clients on the network with the same problem, on cable as well as on wifi (in which case the can see the wifi but not connect to it).
Yes I mean for the router, could be that DHCP does mess things up.
I guess you also factory reset "after" flashing new firmware?
In these cases I power off/unplug the power for my modem and router for 5 minutes, the start my modem first (let it fully startup and configure), then power up my router (R7500).
- That1GuyOct 05, 2015Aspirant
I have a R7000, when I first got it going I LOVED it. Very fast speeds and covered the whole house (which has always been an issue). A few weeks in and it was dropping WiFi, or very slow WiFi or even no WiFi at all (although it would say it was connected).
Long story short I exchanged the Router with Netgear (that process is a whole other story), and the first few weeks it was GREAT! Until it wasn't, and I was having all the same issues. I was about to give up and buy a new router until I saw someone mention a very simple fix.
While doing all the touble shooting I noticed that the router gets very hot. I didn't think anything of it as I was sure that there were safeguards to protect the router from being effected by the heat. In my frustration, I figured it was worth a shot though.
I put a laptop cooling pad under the router... problem FIXED - If you are having issues with your router, check and see if it's hot to the touch as electronics don't do well in these conditions. A cooling pad for a laptop or a small fan works great.
I love this router until it started having all the issues, now with the cooling ($20) i'm back to loving this router. YMMV but it worked for me.
