swehjo
Sep 21, 2015Guide
R7000 drops connection
My R7000 drops connection intermittently since a couple of weeks (I t h i n k it started, at least it got worse, after a late upgrade to V1.0.4.30_1.1.67 mid/end of August). It happens one to t...
- May 10, 2016
Just wanted to chime in here, we have a beta firmware that you may all try.
Lucius1972
Oct 04, 2015Aspirant
Yes I mean for the router, could be that DHCP does mess things up.
I guess you also factory reset "after" flashing new firmware?
In these cases I power off/unplug the power for my modem and router for 5 minutes, the start my modem first (let it fully startup and configure), then power up my router (R7500).
swehjo
Oct 05, 2015Guide
Hmmm... well I check that up even if I can't see that as a sudden, new root cause...
And yes, I do reset and power off before and after the new FW and enter the settings manually.
