Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
Apr 20, 2022Guru - Experienced User
Did you do a factory reset after the changes? the R7000 has responded pretty favorably to resetting after changing firmware. I'd advise during the reinstall to not use a backup configuration
Psychbum
Apr 20, 2022Star
Yes, I actually ended up doing 2 factory reboots and its still the same. So cant see the point in another.
