Psychbum
Apr 20, 2022Star
R7000 ethernet devices missing
Not sure when this started happening but when I go into the web GUI of the R7000 and attached devices all my wireless clients are displayed. But, my ethernet devices are not - the router status light...
Apr 20, 2022Guru - Experienced User
sorry, didn't know if you did or not.
the version thats been the most stable is pretty old. The one we always used to recommend was 1.0.9.42
The .126 version was also fairly stable for those devices it worked well on.
It seems like there's a small percentage of the r7000's that struggle with firmware
Psychbum
Apr 20, 2022Star
Obviously I want to avoid going too far back for security concerns.
What would be your advice here? Which version?
