Cobweb's avatar
Cobweb
R7000 Firmware Updates from v1.0.7.12
Hi,   I recently found my Nighthawk R7000 router and I'd like to use it again.  It's current firmware version is 1.0.7.12, and I'd like to know if the updates are cumalative and I can just download...
  • antinode's avatar
    Jul 14, 2020
    > [...] I'd like to know if the updates are cumalative and I can just
    > download and update to 1.0.11.100 (and the hotfix, too of course) [...]
       I've never seen any requirement for a stepped update on these
    devices.  Presumably the (usually worthless) Release Notes would say
    something if it were.
       I'd run the experiment.  I'd also do a settings reset after after any
    big-jump update (because of my great faith in Netgear router firmware).
