Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
Jan 16, 2022Guru - Experienced User
I would either power OFF the router for 1 minute then back ON, or factory reset and setup from scratch maybe needed.
Miked2
Jan 16, 2022Apprentice
FURRYe38 wrote:I would either power OFF the router for 1 minute then back ON, or factory reset and setup from scratch maybe needed.
Power cycle done...
I thougtht I got away with a clean and easy firmware update, no reset required. Now I remember why I hate this product so much?!
Thx
- FURRYe38Jan 17, 2022Guru - Experienced User
Reset maybe needed...
