Miked2
Jan 08, 2022Apprentice
R7000 Firmware Version 1.0.11.130 - Just showed up Jan 6, 2022
The release notes say only: Fixes security vulnerabilities. Anyone tried this one? I am afraid... But, I always hope they fix some of the other ongoing stuff, like the Attached Devices list m...
SDan67
Feb 04, 2022Tutor
Portwey84
Feb 04, 2022Virtuoso
SDan67 I bought myself a TP-Link AX6600 GX90 gaming router. I'm not a gamer, but it is a tri-band router. I've only had it a week and it's proved itself already insofar as my Wife can now work wirelessly on a separate 5ghz WiFi band without me destroying her connection when I connect via my WiFi6 enabled desktop, which is exactly what was happening with the R7000 when that was running. Yes, she could have been permanently connected via ethernet, but that would have taken some cable running and I cannot be bothered with that.
At the end of the day the R7000 was useful to a point and when it worked, it generally worked well, but sadly NG's dumb firmware updates literally seemed pointless and did in fact cause me issues in the end. The Netgear browser GUI is in my view, appalling and the Nighthawk App isn't exactly cutting edge. But what should we really expect from a now ten year old router design?
