chemasi
Jan 01, 2016Aspirant
R7000 Firmware Version 1.0.6.28 - strange 3rd SSID
The latest firmware update for the R7000 is creating an second 2.4GHz named NETGEAR47-arlo_*random numbers*. I have a separate 2.4 GHZ and 5GHz network that I am already using. I downgraded the r...
- Jan 01, 2016
YES! I'm seeing the same thing.
Look in the Router Settings, Left Column, ARLO: You can enable/disable.
The Help Link states the following:
Arlo
You can turn your router into an Arlo base station by enabling Arlo on your router.
After you enable Arlo on your router, you can sync your Arlo cameras to your router.
NOTE: Enabling Arlo will cause the router to broadcast an Arlo SSID, in addition to the router’s SSID. The Arlo SSID can be used only by the Arlo cameras.
Obi43
Jan 02, 2016Initiate
There is a bug with this firmware, when you disable 2.4G wifi the Netgear ARLO wifi starts. Unckecking "ARLO enable" does not solve this problem. By now only solution is install previous firmware.
AgesBull
Jan 07, 2016Aspirant
Hi Obi43, how do you install previous firmware?
the 1.0.6.28 update does not allow me to connect to routerlogin.net or .com, or connect via the IP address.
Thank you,
