JDinillinois
Jun 27, 2020Aspirant
R7000 Firmware Version 1.0.9.88 and Time Machine
This may have been covered in other threads, so I apologize in advance, but I'm not sure where else to go. All the information about this update and the inability for Netgear to use Time Machine any ...
- Jun 28, 2020
Thank you very much for taking the time to reply, and so quickly. This helps since I was scared away from the update due to the warning.
I appreciate you help.
labatt
Jul 23, 2020Mentor
Time machine support on router does not matter for a time machine back up to a standalone NAS. Time macine support is only if using a drive connected via USB to the router, My MAC backs up just fine to a QNAP NAS without complaining.
minorgeek
Jul 23, 2020Tutor
unfortunately, as i described in my post, at least for me, it fails when backing up to the stand-alone NAS. it seems to go through the backup, try to verify, fail and advise starting a new complete backup. then loops. the NAS and my macbook are on the router's enet, both hard wired. although i'm trying it now to a local disk attached to macbook usb port, bypassing the router, and it seems to be workikng and seems to have succeeded. just lack the mirror image (raid) internal NAS backup.
the nas supports two enets, so i might try connecting a private enet only between the NAS and the macbook, and see if mac recognizes that as a different disk, in which case backing up to the NAS would totally bypass the router.
