plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
Apr 17, 2023Guru - Experienced User
turning off wifi doesn't disable a gateways router function.
It still leaves you in a double nat.
Is the R7000 in AP mode?
Have you tried changing the wifi channel for the 2.4ghz?
2.4ghz is much more sensitive to interference than 5ghz
plegrand
Apr 17, 2023Tutor
Yes
No, i will try
But you think i should upgrade to the latest version without problems ?
Thanks again
- plemansApr 17, 2023Guru - Experienced User
The latest version has been pretty solid.
If both .42 and the .136 version have had the same issue, I wouldn't suspect the firmware.
I'd be more thinking interference or hardware failure if its specific to one band.
- plegrandApr 17, 2023Tutor
I will test the latest version this evening with hard reset before and after upgrade by downloading the latest version from here:
https://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.11.136_10.2.120.zip
Is it the good procedure ?
Nothing else to do when upgrading ?
I will have a look to the wifi channel for the 2.4ghz
I will tell you the result tomorow
Thanks again
And in the case of an equipment replacement, what would you advise me? Not necessarily from the netgear brand đ
