plegrand
Apr 17, 2023Tutor
R7000 Firmware
Hello, I have had a R7000 wifi router for a while now. For some time now I have been experiencing a lot of problems with it (frequent disconnections) The problems came with the successive updates ...
plegrand
Apr 18, 2023Tutor
THen, you recommend this firmware version? (134)
What would be the exact procedure for this update?
this one looks good to you?
Unplug my box from the router
Unplug my box from the power supply
Hard reset of the router
Router update
Router configuration
Turn off the router
Connect the box to the power supply
Wait for it to start up completely
Connect the router to the box
Restart the router
And if you had to advise me a replacement router, which one would you recommend? (not necessarily netgear by the way)
Thanks for your help
plegrand
Apr 18, 2023Tutor
