tcarothers
Aug 04, 2021Aspirant
R7000 Nighthawk AC1900 router repeatedly drops internet connection
Have performed factory reboot, installed latest firmware (1.0.11.126.10.2.112), changed channels, and still drops internet connection several times daily. Router is connected to ISP modem/router Zyxe...
- Aug 05, 2021
> for the R7000 I have Armour security, [...]
That could be a problem. WAP mode disables some router features.
https://kb.netgear.com/000061880
> [...] using it as an access point would it still have a different SSID
> and would its wifi be any more secure and could it be any faster than
> the ISP supplied modem/router or does the ISP equipment act as choke
> point?The SSIDs would still be your choice. WAP2 would still be WAP2, so I
wouldn't expect any difference in wireless security.If you need to use the EMG3415-B10A, then adding the R7000 can't
improve the basic speed. You might see a change in the wireless speed.
Configuring the R7000 as a WAP would make it stupid, thus lightening the
load on its CPU, so an R7000-as-WAP might be faster than an
R7000-as-router.
tcarothers
Aug 05, 2021Aspirant
for the R7000 I have Armour security, using it as an access point would it still have a different SSID and would its wifi be any more secure and could it be any faster than the ISP supplied modem/router or does the ISP equipment act as choke point? Forgive my questions, I have dabbled in computers for 30 years but not facile with the more nuanced aspects of computing.
antinode
Aug 05, 2021Guru
> point?
R7000-as-router.
