jbrownjr
Jul 28, 2019Aspirant
R7000 Router dropping Connection to Modem multiple times a day
Multiple times a day, my internet just goes away. I have to reboot the router to restablish the connection. I do not have to reboot the Modem. Sometimes I work from home my VPN does not drop when ...
- Jul 28, 2019
R7000 V1.0.9.88 causes many problems for many people.
You need to rollback to V1.0.9.42 which people agree is the latest stable f/w release.
Quite EASY to do... on the top, click on SUPPORT. Then enter your ROUTER model, R700 and click on the proper model that shows and press enter. Next screen, click on DOWNLOADS. At the end of the list is PRIOR VERSIONS. V1.0.9.42 the one you want and you see a '+'. Click on that and there are TWO links. Click on the README and just FOLLOW those instructions.
Chonny
Update to my post. (a) I did update the router recently, which is probably significant. Now on firmware V1.0.9.88_10.2.88
(b) Just happened again. I was doing a continuous ping to Google, which interupted; Nighthawk router showed red lights for both Power and Internet (i.e. 2 most-left-hand lights). Self-corrected in about 20 seconds.
IrvSp
Jul 28, 2019Master
