corygehr's avatar
corygehr
R7000 Slow Internet over WiFi
I seem to be having internet speed issues with my R7000. When I watch Netflix on my Xbox One, I notice dropped frames a few times every minute. Sometimes, DNS lookups also fail the first time and I n...
  • VE6CGX's avatar
    VE6CGX
    Aug 05, 2015
    Hi,
    On 2.4MHz band, channel 1,6,11 are non-overlapping. I always tried to use one of these channels. On 5GHz
    I always used hi channels like 149/153, on R7000 this hi channels give better signal level. Don't use
    auto channel selection. Usually if signal level is better than 60dbm WiFi is stable. Playing with antenna
    and position of router can improve signal levels. Set antenna sticks like this   \  |  /, broad side should point to
    general direction of devices.(router front and back) That's what I did when I had R7000.
