junglesim
Jan 02, 2022Star
R7000 V1.0.11.126 -- Remote Management option has disappeared
Hello, I was just looking on the web GUI and noticed that under the Advanced Tab the 'Remote Management' item in the dropdown section on the left under 'Advanced Setup' is no longer there. I pre...
junglesim
Jan 05, 2022Star
Anywhere access via the app works for me too. Not that it matters, but it may help, I noticed one slight change: last week when I connected localled or via anywhere when I wanted to change it to the other, it showed me both options, now it only shows me the alternative to how I am currently connected. So if I'm locally connected it'll give the option to connect via anywhere and vice-versa.
As for the DDNS, via noip.com, that seems to work the same for me as before. Just in case you missed it, 12 months ago or so, noip started to be more restrictive with their free hostnames by getting the user to confirm access once a month.
Please do note that on moving to 128 I have not made any changes that would affect these things, they just work for me.
Bill-D
Jan 05, 2022Apprentice
junglesim wrote:....As for the DDNS, via noip.com, that seems to work the same for me as before. Just in case you missed it, 12 months ago or so, noip started to be more restrictive with their free hostnames by getting the user to confirm access once a month.
I've continued to answer my DDNS confirm email each month. My DDNS was working OK until my Internet IP address changed. If I ping my DDNS URL now it is still translated to my old IP address, so my DDNS via No-IP is partly working - it is translating my URL to an IP address, but its not updating my IP address from my R7000. Also, if I click on "Show Status" on the R7000 DDNS configuration page, it comes back blank instead of showing the latest update as it always did before.
- Bill-DJan 17, 2022Apprentice
FYI - DDNS is working again in my R7000 after the latest firmware update to V1.0.11.130_10.2.118
- junglesimJan 17, 2022Star
Glad to that Bill-D, thanks for letting us know. By the way how do you keep abreast of the updates? I have the router set up to update automatically but it doesn't seem to work.
- michaelkenwardJan 17, 2022Guru - Experienced User
Seconded. Great to have feedback from Bill-D . Any idea why sanity returned?
The most thorough way t keep track if to visit the support pages for the router:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware along with firmware.
Look for the model number on the label on the device.
Experienced users tend to avoid the automated update process. They like to wait to see if there are reports here of problems, such as the death of the Remote Management option!They then prefer a manual update:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
That gives control over the process and means that they can update from a local file rather than something retrieved "on the fly" from Netgears's FTP server. That's usually reliable but you never know when your Internet connection is going to die in the middle of a crucial operation. Manual updates don't even need an Internet connection during the process.
The terminally paranoid will even do manual updates when they get a pop-up alert from their routers.
