ajcanter
Oct 07, 2015Aspirant
R7000 WAN capped
The WAN status used to say 1000M/Full (I'm on a gigabit service) and my tests were around 800 down 250 up but now it says 100M/Full, and my speeds are consistantly 94/94 mb/s. If I directly connect t...
- Oct 12, 2015
Technician came out today, and while working with the network admin group they noticed two different IPs going to the modem. Supposedly two IPs were causing a conflict. They have no idea when this happened. The issue is now resolved and I am getting gigabit speeds through the r7000 once again.
Babylon5
Oct 07, 2015NETGEAR Employee Retired
That would suggest that the link auto-negotiation is falling back to the fast Ethernet rate. There’s no easy way round this, auto negotiation can fail for a variety of reasons. If you have access to a gigabit switch you may find that placing it between the router and the modem can result in auto negotiation working for both segments. Not a solution but maybe worth a try just to narrow down the cause.
- ajcanterOct 07, 2015Aspirant
I'm pretty certain you are correct except that the modem is most likely the issue. Tried two other routers (also multiple cat 5e and cat 6 cables) today and they all appear to be using fast Ethernet instead of gigabit. I'm having a technician come out on Monday.
- netwrksOct 07, 2015Master
If you have a 1000mb switch lying around plug both the modem and router into switch ports. It should negotiate up to 1000mb.
