donEddie7
Aug 17, 2017Aspirant
R7000 Wireless Issues w/ Microsoft Surface Pro 4, Works Fine w/ other Devices
Hello, I've recently begun to have issues connecting my Surface Pro 4 tablet to my home Wifi even though other devices have no trouble connecting via Wifi or Hardwired. My firmware version on my rou...
- Jun 13, 2018
Hi Keigotw,
A new firmware update is available. Please update the firmware to 1.0.9.32.
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
TECHeSmurf
Dec 18, 2017Aspirant
I have the same issue on my Pro3 and Pro 2017.
donEddie7
Dec 19, 2017Aspirant
Support offered to help me out but so far, all they've asked is if I'm using the updated firmware (I am). One "trick" I've found is that if you create a guest network on your router, your Surface will work on that. I've been using it just for the Surface so that I can at least use my Wifi. This is a real pain for such an expensive and (supposed to be) dependable router.
- TECHeSmurfDec 19, 2017AspirantHi donEddie7, I did find this on Windows Central website; http://windowscentral.com/surface-pro-4-slow-wi-fi-fix I made the change, but I'm waiting to see if it makes a difference. Scott
- donEddie7Dec 19, 2017Aspirant
I actually tried this solution once and had no improvement. Maybe you'll have better luck. I recently moved to a New Surface Pro (Surface Pro 5) and still have the issue. There's definitely an issue between that wireless adapter that microsoft uses and the Netgear Nighthawk Router.
