Nikolay
Dec 22, 2015Aspirant
R7000 Wrong Date/Time after firmware update
Dear all, Last night I updated my firmware to Firmware Version V1.0.5.48_1.1.79. Unfortunately now the router is unable to update it's date and time. It stays on 01 Jan 2015. I've reset the t...
- May 05, 2016
I tried all the options given on different forums but no luck. Netgear support gave me beta V1.0.5.49_20151208_timesync firmware which fixed the issue.
[Time synchronized with NTP server] Thursday, May 05,2016 15:25:28
[Internet connected] IP address: xx.xx.xx.xx, Thursday, May 05,2016 15:25:28
[Internet disconnected] Thursday, May 05,2016 15:25:27
[Initialized, firmware version: V1.0.5.49v1.7] Thursday, May 05,2016 15:25:20
madmoggies
May 02, 2016Aspirant
Well that wasn't any good sending in a ticket as I'm well out of the 90 days free support. They say about getting a hardware check done by them but I doubt that would help as several of us have the same problem after updating the firmware. They suggest I get Gearhead Premium Services but that would cost an arm and a leg in call charges from the UK, so I guess I'll just have to wait till the next firmware update.
oseiasslompo
Let's see whether I can help you with your router. When I was trying to solve the problem which was happening to my router I tried many old version until find a version which would fix Date/Time issues. If you don't want the most updated router's functionalities you likely can fix it uploading the FW version R7000-V1.0.3.80-1.1.38. Please try to do that and then tell me what happened. I would do better if my English was better. It's been a pleasure try to help you.
