ADIT1
Jan 06, 2022Follower
R7000P - Can't Disable Remote Management
Firmware: V1.3.3.142_10.1.75 Cannot disable remote mgmt under Advanced/Advanced Setup/Web Services Management I uncheck the Turn on Remote Management box and click Apply. It returns checked....
Jan 06, 2022Guru - Experienced User
Try a different browser?
Is the Nighthawk app connected to the router?
adit
Jan 06, 2022Mentor
Factory default after firmware upgrade - Yes.
Tried Chrome/FF/Edge/IE11. Didn't make any difference. None allowed the change.
Not onsite so the Nighthawk app is useless.
Thanks
