JeffHWI
Jul 27, 2018Guide
R7000P firmware 1.3.1.44 breaks Access Control and Attached Devices
Since upgrading my R7000P to firmware 1.3.1.44, I can no longer see attached devices, and have no way to manage them via Access Control. Before the upgrade to 1.3.1.44, I had Access Control enabled a...
- Aug 04, 2018
BUT, after a couple more reboots things were not visible again. So it looks like reverting to 1.3.1.26 is the solution until the next firmware after 1.3.1.44.
pekbo
Jul 30, 2018Guide
I did downgrade last night. Worked flawlessly. Ignore the warning that your going to replace your current firmware with less recent firmware. All is good.
Netgear QA is frightening me. This issue make all devices invisible to me and I was unable to manage my network. This is a day0 bug that should have been caught with a simple visual inspection of their test networks.
Netgear - please RSVP. Please tell us your are listening and you are going to fix this ASAP. End users need to know about this issue, it's very serious.
Pekbo
JeffHWI
Aug 04, 2018Guide
UPDATE:
I am still on 1.3.1.44 and never reverted. Today I painstakingly did screenshots of my config, then reset the router to factory settings. After putting my settings back in, the Access Control and Attached Devices now works. In addition, both screens actually seem to reflect the custom names that I give devices on either screen.
- JeffHWIAug 04, 2018Guide
- DarrenMAug 10, 2018Sr. NETGEAR Moderator
Can I get some more info on this issue
1. When the device disappeared on Attached Devices page, were these devices online?
2. Are there devices wired or wireless?DarrenM
- pekboAug 10, 2018Guide
Every device disappeared including wired and wireless.
Forgot to answer your 1st question they were all online and functional, just not showing up as attached. I checked them.
- Jjw00dSep 04, 2018Aspirant
Is Netgear working on a fix? If so when is it going to released?
- idazcoSep 30, 2018Tutor
I have the exact same issue with this model and the same firmware upgrade seems to have caused the issue for me as well. Going to down-grade since this firmware is obviously something they pushed in a hurry to get the AppArmor feature out.
