JeffHWI
Jul 27, 2018Guide
R7000P firmware 1.3.1.44 breaks Access Control and Attached Devices
Since upgrading my R7000P to firmware 1.3.1.44, I can no longer see attached devices, and have no way to manage them via Access Control. Before the upgrade to 1.3.1.44, I had Access Control enabled a...
- Aug 04, 2018
BUT, after a couple more reboots things were not visible again. So it looks like reverting to 1.3.1.26 is the solution until the next firmware after 1.3.1.44.
pekbo
Aug 10, 2018Guide
Forgot to answer your 1st question they were all online and functional, just not showing up as attached. I checked them.
JeffHWI
Aug 10, 2018Guide
I had the same experience. Both wired and wireless devices were all able to connect, just not visible on Attached Devices page. And they were also shown as offline on the Access Control page. Rebooting router and devices did not change anything.
- TrifsterAug 15, 2018Guide
My issue is worse. I'm losing almost all but not every single wirelss device on reboots/power failures including LAN devices. Wireless clients can see SSID but nothing is connecting. Factory reset and re-config is the only fix for me and this is now its 3rd failure same exact failure mode. Last night after it happened again due to a power failure (im in NE US getting all the rain) i factory reset it but only turned Circle back on. I usually use Dynamic QoS as well but i didn't have time and wanted to start to triage settings that may be an issue.
From another thread:
Re: Dynamic QoS on R7000P
In the Chinese section, I learned that the customer service told some people that the problem is a firmware issue.
Downgrading or turning on Dynamic QoS can solve this problem.
- JConfortiSep 28, 2018Aspirant
Reverting the firmware does fix the "Attached Devices" issue but you end up losing Armor. For me, Armor was one of the reasons I purchased this router. There are more issues with this version (V1.3.1.44_10.1.23) as well. Under DHCP, I set a reserved address for each of my always connected devices. After resets, or "applies", many times they do not get their assigned address. I hope they fix this soon. Was on the Phone with them today for 40 minutes and I may be given a Beta version. Hopefully, this indicates that they are aware of the issues and are working to resolve them. It is disconcerting that it's been since June 2018 and it has not been fixed yet.
My network isn't that complicated. My old r6300v2 always work flawlessly.
- pekboSep 28, 2018Guide
Due to the issues with this router (R7000P) I have now removed it and it sits in the "for sale" bin in my office. I replaced it with the:
Which so far appears to work fine.
I'm a fan of netgear, just wished they'd stop playing around with ARLO and get back to high end routers for the rest of us.
Rick
- pekboSep 30, 2018Guide
Yes
- ClarDoldOct 20, 2018Apprentice
My attached devices list was just fine on R7000P V1.3.1.44_10.1.23, no access control, no QoS.
I swapped out a wired Netgear WNR1000v3 router that I was using in bridge mode downstream in another room.
I replaced it with a wireless EX7000 which has five ports, and works beautifully, faster than my 100BaseT wired.
One of the wired devices downstream of that EX7000 stopped working. I could see it get an IP address in the logs, but it didn't respond to ping, and didn't work for the IoT application to its host.
I was fussing with that IoT device, and recabling here and there, with an occasional R7000P reboot.
The attached devices went to 0.
I tried setting QoS on, as suggested above. No difference. I still have 0 devices.
I don't know if there is any association between the lost list and the IoT device that isn't working when not attached to the WNR1000v3.
I now have the R7000P, the EX7000 wireless, and the WNR1000v3, with the IOT and a printer.Everything is happy, except the Attached Devices list.
Someone else noted that all of the wired ports are "down". That has been true for quite a while. I think on many releases of firmware.
