Alex101's avatar
Alex101
R7000P router dropping wifi and internet
My R7000P router which cost $300 has been giving me nothing but grief. Since I've had it for some reason it will drop wifi connection to my phone. It will drop connection to the internet. I've got the...
  • myersw's avatar
    myersw
    Jul 05, 2018
    Should i return the box for a refund?
    Yes and get something totally different from another vendor.
    Netgear has had the same firmware issues across all models for months now with no fixes in site .
    All support does is say reset and reconfigure for every issue someone opens. Never make effort to figure out what is happening.
    Got a r8000p cheap should someone be stupid enough to want it.
    IMHO Netgear = Crap.
