Timlab55
Dec 24, 2021Guide
R7350 Married to a AT&T BGW200-700
I'm going to make this as short as possible. If anyone who is reading this knows about the BGW200-700 Gateway/Router will know that the types of services it offers is very low class. Besides gettin...
- Dec 25, 2021
Be sure to make a back up configuration to file for safe keeping. Saves time if a reset is needed.
Dec 25, 2021Guru - Experienced User
that gateway is kind of POS.
I've seen some people get ip passthrough working fine on it while others struggled.
Some have used its DMZ to get the netgear everything forwarded.
And some still can't get full speed with those options and have had to use AP mode on the Netgear.
You might have to experiement and try things.
I thing though. Factory reset the R7350. During the install of it,make sure to leave qos, access control, traffic monitoring, and parental controls all disabled. Those features require packet inspection and it puts a burden on the R7350's cpu. It doesn't have the power to do packet inspection and pass through full gigabit speeds.
Timlab55
Dec 25, 2021Guide
Plemans your great! The first thing I turned off was QoS. On everything including the WiFi. Wow I when from 300 MB/s to 850 MB/s. S Where should I send the check to?
- plemansDec 25, 2021Guru - Experienced User
Lol. You can just set it as 'solved'.
Glad it got it up and working better for you :)
Merry Christmas!
