gstwt60
Aug 30, 2016Guide
Re: R7800 DLNA inconsistent "file not supported or is corrupted" problems
I am also having similar problem. I am not able to get my Nighthawk X4S R7800 to stream video from My Cloud WDBCTL0040HWT NAS Server), Seagate 5TB drive or even a thumbdrive. I get the following erro...
- Jan 10, 2017
Apparently the last updated push has now corrected this problem. I am now able to stream videos via my NAS.
gstwt60
Oct 26, 2016Guide
Apparently I can not get a straight answer from Netgear on this issue. First I was very clear that ANY hard drive, or thumb drive that I connect directly to ANY of my four Rokus will play absolutely every single file. I can also play ALL files to either of my two laptops and I can even play ALL the files on my smartphone. HOWEVER when I route the files going through the router NONE of the previous media will play. The problem is with the router.Please read previous post on this thread before responding.
Elsmicko
Nov 22, 2016Initiate
Yep, I have the exact same problem as you. I bought the R8000 because I wanted to play all the movies I have on my hard drive, but so far all I get is "The media file format is not supported". Not sure what is up with this, but I have the latest firmware version and the router does everything else its supposed to do.
