rbird2
Oct 10, 2017Luminary
R7800 firmware update 1.0.2.36 broke Network Drive - unable to make backups.
Well I unfortunately upgraded to the "Netgear R7800-V1.0.2.36" firmware and found it broke Readyshare with my WD 1TB eSATA drive connected to my R7800. Using Macrium Reflect I was unable to make a ba...
- Nov 25, 2017
Netgear has finally released R7800 firmware version 1.0.2.38 that fixes the Network Drive bug introduced in the version 1.0.2.36 firmware:
http://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.38.zip
JamesGL
Nov 09, 2017NETGEAR Employee Retired
Hi All,
Issue has been reported already and NETGEAR is working on it. I will provide feedback for any updates.
mulhearn22
Nov 09, 2017Tutor
I am also seeing this issue on .36. Going to try rolling back and hopefully that will fix the issue.
- mulhearn22Nov 09, 2017Tutor
Reverting to .32 worked. Didn't have to factory reset.
