tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
Zero_c00l
Mar 23, 2020Star
Yeah I have the same problem. it tries to upgrade and after reboot it's still on the previous firmware (V1.4.1.44_1.3.5). You wouldthink Netgear test the upgrade file before publishing it, but I guess not!!!
DarrenM
Mar 25, 2020Sr. NETGEAR Moderator
I have escalated this issue to engineering to investigate.
DarrenM
- IdahoScottApr 05, 2020Apprentice
Tried applying R7960P-V1.4.1.50_1.3.10 once again. No joy.
This issue has been active now for at least four, maybe five weeks. It appears to me that whatever the issue is, the Netgear engineers cannot, or will not provide a fix. Your best hope is just to wait for the next update, which *** "might" *** work, and apply as designed. If the next one fails, I'm going to reset my router (which should install the original firmware), start over, and see if the new version applies. The problem may not be with V1.4.1.50_1.3.10, but the previous version (in my case, V1.4.1.44_1.3.5). The prior version may be have a bug which prevents new updates from applying.
Again, as I have posted before, if Netgear has a widespread problem with one of their updates (i.e. "widespread"; just google V1.4.1.50_1.3.10 and see how many hits you find), they should recall it, or at least, post some sort of notice on their web site indicating "Hey, we know we have this problem, we're working on a fix, probably in 10 days, just remain on your current router firmware version for now.", or words to that effect. "Crickets" for a response is pretty damning PR for a technology company.
- Zero_c00lApr 06, 2020Star
IdahoScott agreed, this is ridicilous. Don't reset your router, somebody already tried it and it did not work.
- Johnstod1Feb 27, 2021Star
still not working. now several updates later.
- santanderusaOct 10, 2021Initiate
Model: Nighthawk R7960P
To Netgear:
Do you know how many routers a normal user has to buy due to the normal changes of technologies and other matters?
Well, myself has already bought like 10 routers so far, this is ok but...
...after having this issue (not upgrading to the latest Firmware) for almost 2 to 3 years then I am going to use my free-will to try some other router company that dont make it that hard on me to have my piece of hardware up-to-date like Netgear is doing with my hardware.
Netgear, please invest a bit of money on solving this type of everyday problems so you can keep your pool of buyers happy and not pissed off as I am.
- BobtheBuilder99Oct 14, 2021Aspirant
Totally agree. I was considering Orbi, but I'll go with a different company with better customer service. So many users complaining about R7960 not updating and no action by Netgear.
- CarrezeeApr 13, 2020Guide
Thanks. It good when a company stands behind it's products.
DarrenM wrote:I have escalated this issue to engineering to investigate.
DarrenM
DarrenM
- IdahoScottApr 13, 2020Apprentice
DarrenM
Carrezee,You're being too generous, or perhaps, sarcastic?
Darren forwarded this to "engineering to investigate" almost 3 weeks ago. This firmware version (V1.4.1.50_1.3.10) was released as early as November 2019, and problems were reported almost immediately, judging from a quick Google search.
1) Netgear knows that there are problems with this firmware release, and has known about it for at least five months.
2) Netgear has been completely NON-RESPONSIVE to EVERY inquiry about the problem.
3) It was nice of Darren to forward this thread to the engineers, almost 3 weeks ago, but have you seen any other replies? Do a support search (or Google, which seems to return even more hits than Netgear's own search engine), and you'll find MANY threads about this problem software.
I hope that whatever security bugs this version was supposed to fix, were not serious, because otherwise, hundreds of thousands (maybe milions) of Netgear customers are screwed. I've been pretty understanding and patient about this up until now, because I had thought that this version was just released in early March. I've said that Netgear should have rolled back this release already, until they can resolve the problems. However, now that I'm discovering that it was out as far back as last November, I'm done using or buying Netgear equipment. We place a whole lot of trust using their network routers. A compromised network could be financially damaging to just about anyone who connect to a it.
I'm not just the average consumer blowing smoke, either. I'm a professional who has been working with advanced networks and other technology since 1985. I've used Netgear equipment almost exclusively since the 1990's. I'm nobody from nowhere, but Netgear lost this nobody as a customer.
Their non-responsiveness to this issue, is absolutely rediculous. It tells you everything that you need to know about the integrity and quality of this company.
- The_SmurphApr 13, 2020Star
Pretty much said my sentiments exactly to a "T". I love how its been sent, but nothing has been said, not a simple reply, just its been sent. Thanks for the help...... I think I'll look into returning this thing to Costco.
- CarrezeeApr 14, 2020GuideI was surprised to see a legitimate response. Reading through the continuing questions with no offer of solution is disappointing. This is my 3 Netgear router. All prior have been problem free until they died of natural causes.
Currently with the security risks out there, I need my firmware to be solid and secure as I am now working from home with my work issued equipment. - jones2020Apr 16, 2020Initiate
i'm having the same problem. i spent some time before having to go on to this forum. this should be a manufacturing issue, not a community. but here we are, all of us trying to fix the security issue with a bad firmware from the manufacturer. i wonder if i should just return it to costco and get something else like a linksys.
- Juice_22Apr 16, 2020StarI wish I could do that. Because this is very disappointing on Netgear’s part. But I bought my router in early November. So I’m outside the return window. It was working pretty well too before this update.
- SamSundaraJun 07, 2020Guide
Hello DarrenM (NETGEAR Moderator),
Based on your response I see that "you have escalated this issue to engineering to investigate."
Do you have update form your engineering, please let us know as soon as you can.
Thanks
- Juice_22Jun 07, 2020StarI wouldn’t hold my breath to get a response. Netgear has been terrible on supporting this product. I opened a Case 2 months ago and they have been silent on resolving this. They last responded to me about a month ago.
I’ve since moved on to TP-Link. It’s been solid. Unfortunately I can no longer recommend to anyone to use any Netgear product. The TP-Link comes with a 2 year warranty and lifetime built in Network level Anti-Virus and Anti-malware protection. - Tiki-VikJun 07, 2020TutorWell actually I’ve already returned the router back to Costco because I realized that your company does not care about it’s products or ‘it’s customers or it’s consumer base.
- Juice_22Jun 08, 2020Star
Thanks, I returned it this morning. Costco took it back and didn't even question it. I told them the problem and I was recommended to next time return it to Costco instead of trying to get Netgear to fix it.
- sansoo-sdJun 19, 2020Aspirant
Is there a formal solution to the
DarrenM
firmware upgrade NOT working!!!- Wws1Jun 20, 2020GuideMy solution was return the unit and purchased google nest WiFi system.
- SamSundaraJun 22, 2020Guide
Yes that where I am heading, looks like that where Netgear wants all there customer to go.
