tano26
Mar 20, 2020Tutor
R7960P firmware not upgrading
I have attempted multiple times to upgrade my current firmware, V1.4.1.44_1.3.5, to V1.4.1.50_1.3.10 and it fails. I have tried letting the router update itself and also downloading upgrade zip file ...
IdahoScott
Aug 17, 2020Apprentice
What model router do you have? I tried using their alternative process, i.e. both upload from desktop, as well as a script they posted earlier, and no joy on either attempt. One thing I'm not sure I've tried (it's been months), but some of you folks might, is to press the "reset" button in the back. It'll clear all your settings, and *** MIGHT *** reload the original firmware software. (Probably not, because firmware is usually independent of your appliance.) Failing that, ask for instructions on rolling back the current version installed. Next time you run the standard router update, it should pick up the latest version, and hopefully, skip over the buggy firmware version installed.
However, I won't be doing any more of this. I just ordered the TP-Link replacement, pulled out my netgear box and receipt, and in about 5 days, this thing goes back, and I'm out of Netgear for good. LOL, I've wasted literally hours trying to find, develop, coax a solution for this bug, and I think I've put in more time than anyone at Netgear has, resolving this bug.
CKopp wrote:Update: I have sucessfully upgraded to the latest firmware.
I called netgear support. At first they did not want to help because my free 90 days expired about 30 days ago. However, I pointed out to them three things: 1. The problem has existed since before my support expired. 2. I do have an Armor subscription, and how do I know thats not causing the issue, 3. They are the ones sending me emails telling me i need to update my firmware.
So they agreed to send me to tech support. Having explained my previous attempts, they had me:
1. Do the check for update with the browser - same result no new firmware.
2. Redownload the .62 firmware update from the link in the email (looks like the same location as for downloads navigating there via the menu
3. After extracting the file, they asked me to move it to my desktop
4. browse to the file, and execute the upload process.
The upload started, progressed along smartly for about 1 min, and then the reboot message flashed up on the screen.
I checked the router and it was re-booting. This is in incontrast to last time when the upload moved more slowly, hung at 100% for 30 min, and the router never rebooted.
I don't know if this download was different, there is some wierd internal pathing that looks something that makes a desktop firmware location different, or just the luck of the draw..... but it did work this time so maybe you guys want to try again?
Goodluck!
Mrfatboy
Aug 17, 2020Star
CKopp. & I were both on V1.4.1.50_1.3.10 . Some how we both made it one version more than most people.
I will attempt the desktop file update soon and report back.
As for the “update file has to be on the desktop” issue, I have seen it before. My old brother printer had the same installation issue. Crazy.
- PaulTraceyAug 17, 2020Star
Thanks Mrfatboy I really hope it works for you, and then you and CKopp can help the rest of us figure out the missing detail preventing a successful upgrade. Because the firmware file apparently was pushed successfully to the router, this shouldn't be an issue but what browser are you using for the upload? I've tried the latest Edge, and earlier Chrome. Again because other have tried with Tftpd64 I can't imagine how that should make any difference. Just to be sure it's not a browser cache issue reporting the firmware version I cleared both earlier and that made no difference.
- CKoppAug 17, 2020Apprentice
My Firmware before upgrade was :V1.4.1.50_1.3.10. After I am on: V1.4.1.62_1.3.22.
My model is the Netgear R7960P that costco sold. I attached the file I used. At lease I tried too (choose file option) not sure where it went?
- MrfatboyAug 17, 2020StarSuccess!!!! I’m upgraded to the latest👍
Using windows 10 and chrome.
I unplugged the router for 5 minutes. Went to take a shower🤣
Came back, plugged in and powered on.
Move the .chk to desktop ( took it out of zip folder also)
Logged into my Netgear admin panel. Clicked Advanced->Administration
Browsed to the chk file. Uploaded.
In the lower left hand corner there is an upload percentage. This was previously stuck on 1% for me on previous attempts. Went fast now.
Router rebooted.
It took about 2 minutes for entire process.
Good luck👍 - StinsonddogAug 17, 2020Star
I was able to get V1.4.1.62_1.3.22 after being on V1.4.1.50_1.3.10. Again from a desktop load.
I also am on windows 10 pro (v2004) and used Chrome (Version 84.0.4147.125 (Official Build) (64-bit) this time.
One other thought. in the past a couple of times I had noticed that the router was acting a bit flakey, so I rebooted it and it was fine (used to happen all the thime with my dlink gamesing router.
Based on what I did and people are now reporting I am wondering if the best chance might come from:
1. Power off the router for a couple min
2. Power on the router
3. Reboot PC to reaquire IP from DHCAP
3. Download new firmware and extract to desktop
4. From a wired connection, invoke the firmware update process from the console using the desktop file
Maybe?
- MrfatboyAug 17, 2020StarI hope everyone is using a wired connection 😳
Wow, so happy to hear people having success, (because waiting for the Asus routers I'm interested in to be avaiable will be awhile) - and thank you all for the detailed steps. Because I'm new here and don't know where to look for an attached file, Mrfatboy did you have sucess w/ the firmware on Netgears download page?
I don't know why having it unplugged before the attempt would make a difference but I will try that soon along w/ using Chrome from start to finish. I'm also running Win10 (2004 latest updates).
I'm using a wired connection and I saw the upload progress %status very quickly run from 1 - 100, then I saw the router reboot...but I didn't see it slow blink only a couple of lights for some number of minutes - which made me suspect that after reboot it didn't attempt to flash. In fact the time to reboot was so quick I'm pretty sure that's what's happening with mine. Finally earlier I unplugged all connections, rebooted the PC as just suggested and it didn't make a difference but I'm happy to try that again as well. Again, I suspect my problem is that after the download the flashing process is not initiating for some reason. Makes me wonder if there's some previous setting preventing. One maybe unusual thing I've done is reduce the wireless power below 100% (because I live in a small house and want to minimize exposure if I don't need the coverage) but I doubt a wireless setting would impact it. I might just be unluckly. Curious to keep reading if anyone else fails in the way I'm seeing.
- MrfatboyAug 17, 2020StarI downloaded the upgrade file from the Netgear website.
Thanks Mrfatboy and CKopp for trying to help. CKopp , when you said "invoke the firmware update process from the console using the desktop file...is that equivalent to browsing to the routerlogin/start portal->Administration->Router Update etc?
Darn, no luck for me after unplugging all connections, rebooting and uploading using Chrome through the web portal app. After my wife's meetings this week where she needs a connection, I may try the longer method to push the file to the router using Tftpd64 or windows' utility, but by all indications the upload process isn't the problem. I'm not surprised but my hopes were going up seeing so many successes. I am hesitant to attempt a factory reset to force a downgrade in case that doesn't work, since I won't have a replacement router to fall back on for probably over a month if I order the one I'm interested in today. In the meantime, I'll definitely watch this thread to see if there's a trick I missed or got wrong. Thanks all.
- MrfatboyAug 17, 2020StarWhat are you seeing? How far did you get?
Not sure if this is a notable difference, but I allways access the router via its IP directly. The default should be 192.168.1.1.
Once in (at 192.168.1.1/start.htm, I navigate to the Advanced/Administration/Router Update page.
routerlogin is resolving to http://192.168.1.1/start.htm ok but thanks for any detail.
I'm just a bit sad because to add to the other problems I have w/ this router - I have a few duplicate IP's being assigned to important devices, which I can't seem to fix now either. Just so many bugs...*sigh* Mrfatboy the upload of the update makes it to 100%, most led's turn off, then 3 red adjacent lights come on for a few seconds, the router shuts off, powers on, then boots up like normal (unfortunately). I recal when flashing firmware successfully before, or after the reboot. Oh and after the reboot my wireless network is now called "living room speaker" even though the SSID hasn't changed according to the admin portal!?! I'm back to being extremely frustrated and tired. Is there a press and hold the reset button type of option to return it to it's initial firmware?? or would my only chances be to try and down grade flash to a previous version. At minimum I need to keep the wired computer running for my wifes meetings tomorrow.
2 cents recommendation from a really old guy - replace your current router (Trendnet in my case) before it becomes too flaky - just so you have a backup in case your new router goes foobar like this Netgear.
BTW, sad and tired + frustrated is more accurate. Speaking of which I could take notes of which led's come on in what sequence but it's in another room and I'm just kindof tired. If that would help diagnose a fixable problem I am willing, otherwise I need to take a break and fix something (like our screen door) that's fixable, to improve my mood ;-)
So those on V1.4.1.44_1.3.5 haven't been able to upgrade but a few of us on V1.4.1.50_1.3.10 have been able too? Isn't that the issue that started this dialog? That firmware 1.4.1.44 is blocking further upgrades. Not sure much has advanced here unless I missed something.
sorry for the multiple posts...I just read one google article on a factory reset and duh...it resets all the settings - which I'd rather not do, but (as makes sense) not the firmware...
Tomorrow I'll try a factory reset, then for the heck of it try the firmware upgrade one last time, and if that dosen't work - apply a saved backup config file (doh, I forgot about that).
- andynbakerAug 18, 2020GuideI'm still on 1.44 and cannot upgrade to 1.62. I've tried uploading through the admin panel, and tried to handle it with tftp, but no dice. I tried moving to 1.50 fussy but can't get that to take either. I think I'll just return it while I can. I'm done messing with this stupid thing.
- StinsonddogAug 18, 2020Star
To summarize, if you are on 1.44, now is the time to return your device to Costco and pick something else during their Network sale that is going on right now.
Something about the 1.44 made it no longer possible to do firmware upgrades. Mine was replaced with a 1.44 version that didn't have that issue and it made the leap to 1.50 and now 1.62.
Take action now while Costco is giving you a variety of choices.
Just ordered a TP-Link C4000. As soon as it comes in the R7960p is going back to Costco. I'm done with Netgear.
- CKoppAug 18, 2020Apprentice
Just to be clear, when I was on 1.50, I also had problems getting the upgrade to take place. I am no longer sure what I was on before 1.50, but I know I upgraded once between when I bought it in April 2020 and now.
Yeah i've tried to move to 1.50 like ten times at this point. Both through the GUI and through tftp. I had to borrow a windows machine to take a stab at the tftp approach but was never able to even get confirmation of upload. I have a raspberry pi that i think i could tinker around with and get tftp-hpa working, but i'm just done messing with it. I don't want to have to keep messing with this stupid thing that I expect to just work and keep my local network safe.
I've been really happy with these products up until now. I may be in a minority, but i like the netgear router GUI. And i've been impressed with what can be configured out of the box, like VPN, access control, etc. I've just been blown away by how piss poor the response has been with this issue, especially given the recent news of Netgear router hacks through remote router management.
I have no idea if the TP-Link product will be any better, but i doubt it can be any worse. And at this point I feel like I have no other option.
- MrfatboyAug 18, 2020StarHave any of you tried the 30-30-30 reset before the install?
https://www.router-reset.com/info/Netgear/R7960P - andynbakerAug 18, 2020GuideI haven't recently. I figured if I have to set VPN and DHCP stuff back up thev I may as well do it with a new router and not bother with this one any more. If Costco doesn't take it back for some reason they don't take it back then I'll give it a go.
