samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
michaelkenward
Oct 11, 2020Guru - Experienced User
That could mean many things.
What are you doing and where does it go wrong?
Support can only help when it knows what is going on. You have to explain things to them, before they can help.
- samfromcoOct 12, 2020Guide
Hi michaelkenward,
I have clicked on update firmware button on the top when I login to router admiin console, router goes through the update firmware process, reboots and the firmware version remains same as the old one and it is not updated.
I did Reset the router to factory defaults to ruleout any configurtion settings issues, repeated the same steps as above but the result is same.
Then I have downloaded firmware, unzipped and tried to update firmware by uploading *.chk file and same result.
Please suggest what else I can do.
Thanks in advance
- michaelkenwardOct 12, 2020Guru - Experienced User
Which firmware version do you have now, and what are you trying to move to.
Your subject says R7960P but the footer in your message says R7900. Which are we talking about?
New firmware is found. Do you want to update the firmware? (Yes) (No)
Current Firmware Version 1.4.1.44 New Firmware Version 1.4.1.64_1.3.25 Release Notes 1. [New Features and Enhancements] Supports NETGEAR Armor 2. [New Features and Enhancements] Improves the device type and model detection 3. [Security Fixes] This firmware fixes security issues. 4. [Security Fixes] This firmware fixes security issues. The one I have is Nighthawk R7960P
