samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
samfromco
Oct 12, 2020Guide
Hi michaelkenward,
I have clicked on update firmware button on the top when I login to router admiin console, router goes through the update firmware process, reboots and the firmware version remains same as the old one and it is not updated.
I did Reset the router to factory defaults to ruleout any configurtion settings issues, repeated the same steps as above but the result is same.
Then I have downloaded firmware, unzipped and tried to update firmware by uploading *.chk file and same result.
Please suggest what else I can do.
Thanks in advance
michaelkenward
Oct 12, 2020Guru - Experienced User
Which firmware version do you have now, and what are you trying to move to.
Your subject says R7960P but the footer in your message says R7900. Which are we talking about?
- samfromcoOct 12, 2020Guide
New firmware is found. Do you want to update the firmware? (Yes) (No)
Current Firmware Version 1.4.1.44 New Firmware Version 1.4.1.64_1.3.25 Release Notes 1. [New Features and Enhancements] Supports NETGEAR Armor 2. [New Features and Enhancements] Improves the device type and model detection 3. [Security Fixes] This firmware fixes security issues. 4. [Security Fixes] This firmware fixes security issues. The one I have is Nighthawk R7960P
- michaelkenwardOct 12, 2020Guru - Experienced User
From 1.4.1.44 to 1.4.1.64 is not a huge leap. Sometimes there are so many stages in between that you have to work your way up.
You could try a manual update to 1.4.1.50 to see if this unsticks the process.
If that takes move up to the next level.
- samfromcoOct 13, 2020Guide
Hi,
Tried to upgrade to version 1.4.1.50 (for R7900 as I couldn't find one for R7906) both manually and tftp way and no success.
Thanks
- kmich2001Dec 06, 2020Tutor
I have same issue identified as others. I get an update found indicating my current firmware 1.4.1.44 has a new version available 1.4.1.64_1.3.25. When I selrct update, the router does reboot however the vession number does not change and indicates the same is available to update. I have reset factory settings and I continue to get the same issue. Any ideas on how to get the firmware update to work?
- michaelkenwardDec 06, 2020Guru - Experienced User
- kmich2001Mar 19, 2021Tutor
The reply "Model #" does not allow R7960P. it only allows R7900.
- michaelkenwardMar 19, 2021Guru - Experienced User
Not for the first time, Netgear's database is out of date.
- yorugua2001Jul 13, 2021Initiate
having the same issue, tried manually upgrading and haven't worked, it works great but the firmware is outdated, another issue that has is that sometimes when i reboot it, it looses all the settings.
