samfromco
Oct 11, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 02, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
michaelkenward
Mar 19, 2021Guru - Experienced User
PalmSpringsBill wrote:
I tried update through Nighthawk App and says successful but firrmware version never changes.
I've tried with browser over wifi with router login page and it errors out.
Experienced users caution against using these routes.
Automated updates require the router to go and get the file, store it in memory and then run the update. It doesn't take much imagination to see how things can go wrong in comparison with downloading the file yourself and using a wired connection to do the upgrade.
But as you have found this doesn't always stick.
PalmSpringsBill
Mar 19, 2021Tutor
That's not very helpful :-)
So basically not follow the manufactureres instructions.
- michaelkenwardMar 19, 2021Guru - Experienced User
Those are the manufacturer's instructions
