samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
michaelkenward
Mar 19, 2021Guru - Experienced User
kmich2001 wrote:
The reply "Model #" does not allow R7960P. it only allows R7900.
Not for the first time, Netgear's database is out of date.
yorugua2001
Jul 13, 2021Initiate
having the same issue, tried manually upgrading and haven't worked, it works great but the firmware is outdated, another issue that has is that sometimes when i reboot it, it looses all the settings.
- MarkSparksJul 14, 2021Aspirant
So this issue has been reported here and languishing for almost a year now and there is COMPLETE RADIO SILENCE from Negear. This is unbelieveable to me. I am sure they monitor this forum but do not want to have to answer the question "Why isn't Netgear fixing this problem?!"
It must be a "hardwired" problem that they don't want to have to issue a recall of the units to fix. They are leaving it to us to "eat" their mistake. Unbelievable!! At least there are other good manufactures of routers and switches out there. No more Netgear junk for me!!
- kmich2001Jul 14, 2021Tutor
I returned mine and moved on to another manufacture.
- J357Sep 23, 2021Initiate
Firmware upgrades do not work at all, manual or automatic (web based) updates.
Same problem as others. I follow the Netgear instructions exactly:Download file, start the update, it runs through the process, reboots, then lists the same old version as before. I have tried this 5 times with different legacy firmware versions with no change.
Statistics:
Model R7960P (Costco version which is not listed in model dropdown).
Old firmware: V1.4.1.44_1.3.5
Attempted new firmware: V1.4.1.82_1.3.40 hotfix
Maybe it really does update but they forgot to update the version number in the header so it always reports being out of date. In any case, very amateurish for a supposed technology company. As others have said, there is no real support.
- PalmSpringsBillJul 14, 2021Tutor
I am with you 100% and won't buy another Netgear modem/router after this... but is your router still working? Mine still provides strong internet access so takes some of the sting away.
What exactly did the firmware upgrade do?
