samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
dev70000
Sep 29, 2021Guide
have you tried the latest hot fix which was released in July 2021
JROQ
Sep 30, 2021Aspirant
R7960P-V1.4.1.82_1.3.40_hotfix - Yes I did.
I tried manually, 3 different browsers, using th "BASIC" and "ADVANCED" tabs.
I have also attempted to do it with only 1 computer connected.
This router cannot be updated.
- dev70000Sep 30, 2021GuideI talked to netgear support and they pre-authorized 50$ support and promised they will only charge once the issue is solved. They tried all the basis/advanced and manual stuff but it didn’t work. Today they will call to perform some update using tftp procedure. Will post the results.
- yorugua2001Oct 01, 2021InitiateThanks for keeping us informed, I don't consider myself a newbie even it comes to computers, I have owned computers, routers, etc for more than 20 years and i tried everything even the ftp upload without success, hopefully Netgear can figure something out because i really like the router otherwise
- dev70000Oct 05, 2021GuideThey tried tftp method, it didn’t work either. We weren’t able to put the router in tftp mode itself.
I bought this router from costco. Model is R7960p.
If anyone wants to try tftp method link is below. I Wasted almost 8hours.
Please take a back of all your configs before you start.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
